Oil Pressure Problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2007, 11:15 PM
I have just rebuilt a 350 SBC and have a prob with the oil pressure, at 2000 RPM it used to run at 40 psi now when it's hot it runs at 30 psi at the same revs but if you take your foot off the gas the pressure increases to 40, I can vary the oil pressure up and down with the throttle when I'm coasting at 2000 rpm. Has anyone got any ideas?
Old 09-13-2007, 12:20 AM
DoubleVision's Avatar
Welcome to Hotrodders Rust. Being you didn`t say if you have a electrical gauge or mechanical gauge, all I can say is if electrical, check and clean the sending unit. How old is the gauge? If mechanical, how much air does it have in the line? It really don`t sound like it has a oil pressure problem it`s just tending to move around more than you perfer.
Old 09-13-2007, 03:31 AM
Preessure Gauge
It is a mechanical gauge, and I have bled the air from the line
Old 09-13-2007, 05:55 AM
opinionated old fart
Last journal entry: Sheetmetal
If you built it with a no bypass filter adapter try a new oil filter, if the block wasnt cleaned real well after machining it wont take long to clog the filter.
Larry
Old 09-13-2007, 06:01 AM
Hi, if you know your engine clearance's are all correct, and you ruled out air in your gauge line, i would guess that your pump pickup tube could be loose, sucking air, or the tube is to far off the bottom of the pan. I like to see the pickup 3/8 off the bottom. good luck sam-missle
Old 09-13-2007, 04:20 PM
Filter
I,ll change the oil filter today and post the result
Thank you
Old 09-13-2007, 06:39 PM
Jmark's Avatar
I don't think air in the pressure guage line will be a problem. Pressure is pressure, whether it's full of oil or air.
Old 09-14-2007, 12:55 AM
I have just put on a new oil filter and the problem is still there.
Old 09-16-2007, 10:41 AM
Magikal's Avatar
How can it go faster?
Last journal entry: Been a long Winter
pressure is pressure, yes, but air will compress under pressure. Oil will not.
Old 09-16-2007, 01:54 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I've never had problems because of air in my oil pressure line, it seems to work the same either way.
When you say you can vary the oil pressure with the gas peddle, does the oil pressure seem like its connected to the acceleration of the vehicle? if the pickup is cracked it could be the oil is sloshing away from it and exposing air.
Old 09-19-2007, 11:25 AM
Oil pressure problems
I had a similar problem on a 415 sbc stroker I built, with some help from this forum it turned out to be to much oil in the pan. I run 6 1/2 quarts in a 7 quart pan and my oil pressure problems went away. Turns out the crank was foaming the idle I would loose pressure about 3000 rpms and as soon as I let off the pressure would go up. Might be worth a shot.
oil psi problem w/350 A355CAMARO Engine 2 04-19-2007 07:25 AM
fram oil filter lower oil pressure elvis 66 chevelle Engine 33 09-14-2006 04:36 PM
Found low oil pressure problem.... kc_ksom Engine 2 09-06-2005 07:01 PM
No Oil Pressure!! MartyMart9@aol.com Engine 43 04-26-2005 06:37 AM
It's alive...finally AngliaBob Engine 5 02-19-2005 12:46 AM
