Oil pressure problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2005, 10:18 AM
blacklotus's Avatar
Greg
Last journal entry: Wiring begins
I have a 96 Jeep Laredo with a 6 cylinder inline. When I am driving down the road normal speed I have about 70PSI oil pressure, but when I brake the oil pressure drops to zero and the warning light and audible alarm will sound and then the oil pressure will rise to 20PSI at idle. This all happens pretty quickly.
I think the oil pressure sending unit is the problem, but I am not sure. It is full of oil.
Does anyone have any ideas?
Thanks
Old 07-13-2005, 10:28 AM
Last journal entry: PICTURE TEST
engine
How many miles on the engine....
If you brake slowley does it still happen????Or only with sharp braking???
Keith
Old 07-13-2005, 10:31 AM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
i can tell you to check the wiring.
i dont know about computerized stuff 2 much but if you cant figure it out put a "T" on it and put a mechanical gage on it ...if there is room
i would check the plug
then replace the unit maybe some one else can tell you how 2 check the unit
good luck
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 07-13-2005, 10:43 AM
blacklotus's Avatar
Greg
It is possible to stop slow enough that it will not do it, but you have to almost crawl to a stop
Old 07-13-2005, 10:50 AM
oil
Ok,,, well do the basics first check the gauge and sender.
Does this car have a tach in it??? I was wondering if the rpm is falling off during braking???
Keith
Old 07-13-2005, 11:20 AM
SmallBlock_guy's Avatar
Jeep dash oil indicator
I seem to remember from my DCX days that the oil indicator on the dash is a switch not a gage. It is driven off of the JTEC (PCM) and is fed a "yes" or "no" signal.
I would put a real pressure gage on it and verify the readings.
Old 07-13-2005, 11:49 AM
Big Block Z28
I once had athe same problem on my SB Z28. The oil pump pickup came off the pump and when I'd brake the oil was forced forward and the pump couldn't pump it. It was the factory pump so the pickup wasn't welded to the pump. You'd have to pull the pan to find out.
Old 07-13-2005, 01:09 PM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
I agree, I think there's a chance you're not getting oil at the pickup in your sump when you brake.
what's your oil level like? you could try running an extra quart or two right before an oil change and see if it affects the problem.... i.e. if your pickup has fallen off, the extra oil might prevent the pump from sucking air during braking, and you have a pretty good idea you need to pull the pan off to fix the situation.
good luck
the blonde weasel
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
Dropping Oil Pressure!! camaro409 Engine 14 05-31-2005 06:36 PM
Low Oil Pressure on Buick 3.8L V-6 TravisT Engine 8 03-31-2004 11:12 AM
No Oil Pressure with normal operating tempature jrm123180 Engine 3 03-03-2004 03:56 PM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
