I've done a bunch of big and small blocks and only use the one without the collar. As long as you prelube all contacts surfaces, valves, cam lobes, flat part of lifters and both ends of pushrods, you'll be fine. Prelubing cam bearings and crank and rod bearings is great for turning for assembly but if you spin the oil pump the oil will dilute the prelube on those pieces. Rocker arms, cam lobes, lifters and pushrods will retain the prelube until you fire it and then after running it will wash off. Never had to pack the pump.
If everything is right to fire you have no problems |
| oil pressure question | jody chevelle | Engine | 16 | 08-02-2010 06:59 PM |
| Fabricating intake manifold. | gemini86 | Engine | 25 | 10-02-2009 01:10 PM |
| Question on oil pressure switch with electric choke | grobb284 | Electrical | 6 | 05-05-2009 08:33 PM |
| Oil pressure question. Daily driver's getting old. | GMW | Engine | 19 | 12-14-2006 10:09 PM |
| oil pressure sending unit? | Brian Morency | Engine | 2 | 07-21-2004 03:43 PM |
