I would use the sending unit from the S10 ... so it would be calibrated correct to the gauge. You may need a spacer or a 45 degree angle fitting.
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
A 1/8" NPT (pipe thread) coupling and a nipple of an appropriate length will raise the sender enough to clear the intake. Try a local parts store or a plumbing supply store. Pep Boys had a pretty good selection of brass pipe fittings when they had a store here. If you want to put it at an angle instead of straight up, use an elbow, either 45* or 90*, instead of the coupling.
| oil pressure switch | Blob | Engine | 7 | 12-02-2005 12:34 PM |
| Oil Pressure Sending Unit | whsipersix167 | Engine | 2 | 11-13-2004 05:59 PM |
| Oil pressure loss SB Chevy | Finmike | Engine | 30 | 06-12-2004 10:27 AM |
| No Oil Pressure with normal operating tempature | jrm123180 | Engine | 3 | 03-03-2004 02:56 PM |
| Oil Sending Unit Assistance | MI2600 | Engine | 3 | 09-11-2002 07:55 AM |
