Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil pressure sending unit leaks
Old 10-01-2012, 03:47 PM
RWENUTS's Avatar
RWENUTS RWENUTS is online now
If this is the style of hookup you have then you need to replace the little sleeve in the middle. It slides over the tube and is compressed to seal inside the fitting.
How To Indetify Fittings Another Style Compression Fitting Photo 19
