Originally Posted by Lthompson
My oil pressure guage is the type that has the little oil line that runs from the back of the motor. Ive tried several times but it has always leaked right where the hose goes into the brass fitting going into the motor. What is the trick to getting these to not leak?
After a compression fitting is taken off and on a few times they can get to the point where they no longer seal. If you have a plastic line, cut it squarely to remove the
ferrule that's crimped onto the line.
Most any parts house will sell you a small bag of replacement ferrules for a pittance, reuse the rest of the fitting as long as the threads are OK.
