Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil pressure sending unit leaks
Old 10-02-2012, 11:49 AM
Live Action! Live Action! is offline
Oil line leak
I had the same problem when I installed mine, when you screw in the fitting going on to the manifolid I use permatex utra cooper silcone around threads. Next put the plastic tubing throught the cuplink then the little cuplink with enough tubing to fit a the way down aplly the silcone around those threads also. last tighten down and make sure your not cross threading, do the same to the guage in the car the silcone will prevent it from leaking. If all else fells Autozone has a kit that comes with the tube and fitting for like $5 bucks to start over. Hope this helps
