oil pressure sending unit leaks - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2012, 03:17 PM
My oil pressure guage is the type that has the little oil line that runs from the back of the motor. Ive tried several times but it has always leaked right where the hose goes into the brass fitting going into the motor. What is the trick to getting these to not leak?
Old 10-01-2012, 03:47 PM
RWENUTS's Avatar
If this is the style of hookup you have then you need to replace the little sleeve in the middle. It slides over the tube and is compressed to seal inside the fitting.
How To Indetify Fittings Another Style Compression Fitting Photo 19
Old 10-01-2012, 06:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
After a compression fitting is taken off and on a few times they can get to the point where they no longer seal. If you have a plastic line, cut it squarely to remove the ferrule that's crimped onto the line.
Most any parts house will sell you a small bag of replacement ferrules for a pittance, reuse the rest of the fitting as long as the threads are OK.
Old 10-01-2012, 07:06 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
The complete fitting part number is a Weatherhead # 68x2 (Retail $1.40 CDN)
which is 1/8 NPT pipe thread on one end (which screws into the engine), and the other end is a 1/8" tube compression fitting.
You can buy JUST the ferrule if you like.
Weatherhead P/N for that is 60x2. (Retail $0.17 CDN)
Also ... I dislike / distrust plastic tubing as I had a bad experience. My brother borrowed my car, and the tubing blew out of the fitting. It's amazing how quickly you can drain an oil pan out of a 1/8" diameter hole with a high-volume oil pump.
To complicate matters, he broke the brass fitting off clean at the engine while attempting to tighten things up again. (He was 17, I was 21 at the time.)
Needless to say, there were a few cuss-words uttered as I used an easy-out to remove the broken fitting.
I played it safe, replaced the platic tubing with copper. Yes, I made the line long enough to add a couple of 3" loops to accomodate engine movement and vibration.
Old 10-02-2012, 10:49 AM
Oil line leak
I had the same problem when I installed mine, when you screw in the fitting going on to the manifolid I use permatex utra cooper silcone around threads. Next put the plastic tubing throught the cuplink then the little cuplink with enough tubing to fit a the way down aplly the silcone around those threads also. last tighten down and make sure your not cross threading, do the same to the guage in the car the silcone will prevent it from leaking. If all else fells Autozone has a kit that comes with the tube and fitting for like $5 bucks to start over. Hope this helps
Old 10-02-2012, 11:24 AM
RWENUTS's Avatar
Bad idea!
Use a sealer for the fitting into the block but never use sealer on a compression or flared fitting. JMHO
Old 10-02-2012, 03:01 PM
ive tried two kits so far. Both leaked. Guess ill try again.
Old 10-02-2012, 03:26 PM
oil pressure fitting
Worked for me! keep on keepin on!
Old 10-02-2012, 03:28 PM
OIl pressure fittings
I didn't mean but silcone all over the place just the treaded area's must be reading to hard into it!
Old 10-02-2012, 05:18 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Do yourself a favor and replace the plastic line with copper. I had a 68 RS SS Camaro with the plastic line and it broke at the gauge in the console and pumped 4 qts. of oil in my floorboard before I knew what was wrong.
Old 10-02-2012, 06:53 PM
66GMC's Avatar
Ditto.
Do it right.
Do it once.
Old 10-03-2012, 11:38 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Plastic line can be run inside vacuum tubing to protect it and prevent kinks. Similar to how the OEM did w/copper tubing- before they discontinued using it in favor of steel or plastic, they used a bonded rubber outer covering on them especially in places where there could be contact w/anything. The factory also used a double loop at the end to help keep the copper line from breaking from metal fatigue or work hardening and to compensate for temp changes.
If the line is going to be changed, change it to something that's better than either: Braided Stainless Steel Mechanical Gauge Hose Kit
compression fitting, ferrule
oil pressure sending unit jamesoldlym15 Engine 1 04-19-2009 05:04 PM
Oil Pressure Sending Unit awoodman Engine 3 11-29-2008 10:17 PM
oil pressure sending unit fireguy Engine 5 02-11-2005 09:09 AM
oil pressure sending unit? Brian Morency Engine 2 07-21-2004 03:43 PM
Oil Pressure Sending Unit? TonyMac Engine 2 03-19-2004 05:41 AM
