Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil Pressure Switch and Temp Sending unit
Old 05-18-2008, 10:01 AM
Deuce Deuce is offline
As a general rule ... sending units are NOT interchangeable with the stock GM units. I would just wait and get the correct senders.
I had the same problem with a Stewart Warner oil pressure sending unit ( being large ) ... and I ended up using a adapter that raised the unit up a little but had a 45 degree angle in it ... so that it angled the sender away from the distributor.
