I would check the dist. you replaced. The lifter oil galley runs thru the dist shaft - if the machining is not right on the shaft, oil could be by passing causing low pres. Also check galley plugs on front - if loose or missing this will cause low pres.
thanks for the info, the distributor is a new mallory magnetic pickup, also when i changed the filter it had great oil pressure right away then when back to doing it again, can the bypass where the oil filter screws on be causing this? Thanks.
The bypass gets a pipe plug installed in it on my engines.
Along about '86 this filter mount was changed to a different style. |
ok guys so i checked the oil filter adapter and put a different brand oil filter on it. still same results. Ok a old drag racing guy told me that he had a cracked crank shaft do exactly what im talking about, had great oil psi until under a load and the crank flexing opend up the crack and lost oil psi and soon as you lift its back to normal. Ive had alot of grief with this motor, it was built by a man that builds race motors and has built atleast 40 percent of the motors at the track, when i first bought it it was fresh got ten passes on it and it wiped out six rod bearings , now with only 40 or so passes this happend, is it possible this crank could have been the reason for the first bearing failure? Thanks for all the help its frustrating.
This theory could hold water IF the crank's forged steel. They will flex (to a point
) w/o breaking, unlike a cast crank that cannot withstand flex nearly as well.Just for s&g, can you reinstall the original distributor (including the old oil pump drive) and test for oil pressure? |
Oil pump loose. Did you check the front galley plugs??? |
the oil pump was tight, and i havent had a chance to check oil galley plugs, the engine builder wants me to pull it out and bring it back. This will be the fourth time its been in and out of the car, when does a person say thats it and go else where? Ive had to pay money every time weve had it apart no warantees on work but some free labor. Last time he had it apart he wouldnt let me come and get it because he didnt want his name tarnished, so it took another complette rebuild so it cost me almost full price less 300 of labor. Ive paid to have this thing built twice and this will be number three. Thanks for your help
Sounds like it's time to declare "malarkey" on this hack. It's YOUR engine, if he were to hold me up like that, more than his name would get tarnished! LOLTime to move on, cut your losses, and find another wrench, IMHO. |
I may have missed something, but it sounds like this oil pressure issue is only present under acceleration. Is it possible that the pickup may not be sitting deep enough in the pan and under acceleration the oil is moving away from it causing it to suck air instead of oil? Though it may also have contributed to your original bearing failure.
Thanks guys for all your help, im sure the pickup sets deep enuff in the oil its a deep 7 quart pan, what does it meen when someone asked if it could be cavatating the oil pump? I run 10w 30 so its not real thick. Your rite there is alot of great information on this site and i plan on tearing it down and checking it out myself and going from there, ive done alot on top end builds and cam swaps and such just never tackled the bottom end. Thanks again
| Oil Pressure questions | RObs71Nova | Engine | 22 | 05-02-2009 01:45 AM |
| oil change- step by step instructions for women and men | Fireball | Hotrodders' Lounge | 38 | 08-30-2008 07:39 AM |
| Is it no good to have a High volume oil pump? | Calderone | Engine | 17 | 01-31-2008 05:26 PM |
| another oil pressure question | timemachine | Engine | 2 | 09-26-2007 09:26 PM |
| low engine pressure | molevolent_creations | Engine | 14 | 12-24-2005 07:49 PM |
