Oil priming problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2005, 07:32 PM
Oil priming problem
My son and I are finishing up a rebuild of a sbc 350. We have been trying to pre oil the engine with a drill motor. The oil pump seems to be working based on the fact the drill motor is really working hard (to the point of getting very hot) but the oil is not getting to the lifter valley or heads. Anybody have a thought on this?
Old 11-25-2005, 07:44 PM
Are you using a proper priming tool that seals off the lifter galleries? If not you won't get oil up to the lifters. Just a thought
Old 11-25-2005, 08:01 PM
NOlowrider's Avatar
US Navy-Retired
You should at least see some oil seeping onto the rocker arm/push rods.
Old 11-25-2005, 08:07 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I have never had a problem priming with a drill, yes the drill gets hot because that is a load for the average drill. I usually screw a hose in where the oil pressure sending unit goes and put a mechanical guage on the other end of the hose so I can read the oil pressure. If you did not soak and prime your lifters by hand before you installed them it will take awhile to get them pumped up with the drill. Let the drill cool off and then try it some more.
Old 11-25-2005, 08:50 PM
Thanks for the input. 85406, the priming tool is just shaft which engages the oil pump. there doesn't appear to be anything to block off the lifter gallery. I bought this tool at my local parts house. Is there a part number you can give me to get the right one?
Old 11-25-2005, 09:18 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Try spinning the drill in the opposite direction, maybe you are turning it the wrong direction.
Old 11-25-2005, 09:42 PM
Ermmm..
Excuse my ignorance but for future reference - what is the correct direction???
Old 11-25-2005, 09:51 PM
Bumpstick's Avatar
Hammer and a torch
Clockwise... (same rotation as the distributor...)
Old 11-25-2005, 10:03 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Since he said that his drill is working hard it would seem that it's spinning in the right direction. Spinning in the other direction wont put any load on the drill because it'll be trying to pump air backward through the pump and do nothing but aerate the oil.
Old 11-25-2005, 10:18 PM
this is the type of primer I have found works.
Old 11-26-2005, 01:40 PM
I've tried both directions (CW and CCW) CW is definitely harder on the drill motor so I assume that is the correct direction. The tool I'm using doesn't have the two discs shown in your picture 85406, its only the shaft. I guess I need to find one.
Old 11-26-2005, 02:22 PM
If you are not able get a proper primer, you can make one from an old chevy distributor if you have one. Just take the cam gear off, rig it up so that a drill will fit to the top and you are good to use. Another thought would be the fact that the drill got hot means it was pumping oil to the bearings, so you could pour a little oil on the rockers, let some dribble down the pushrods and fired it up with the valve covers loose. It probably will be ok. I wouldn't have a problem doing that with any of my mostly stock motors. I wouldn't do it with my race motor. Make sure when you get it running to check oil pressure and to run it for 20 min at 1800-2500 before shut down.
Oil pressure problem blacklotus Engine 7 07-13-2005 01:09 PM
AMC 360 oil problem ChevelleSS_LS6 Engine 6 09-23-2004 01:15 PM
MGA oil filter problem 1961_MGA Engine 2 06-01-2004 06:04 PM
Oil Pump Problem??? riesman20 Engine 11 05-25-2004 11:06 PM
oil pump priming MardyMar Engine 1 05-03-2003 04:46 AM
