Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil psi and not so much psi
Old 09-10-2012, 11:10 AM
Choctaw Bob's Avatar
Choctaw Bob Choctaw Bob is offline
Originally Posted by gongchuan View Post
Id like to know a little more about this oil bypass block off. This is something that can be blocked from an external point or are we talking directly on the pump itself?
Im trying to avoid pulling the engine. As described this motor is just to get me bye until I have one that is on the stand finished.
The oil filter bypass is in the plate the oil filter attaches to. You can by a plate without a bypass or block the stock one yourself. Just make sure you use high performance filters because sometimes cheap filters for chevys will blow up. Never a problem for fords cause they don't have a bypass.
