Oil psi and not so much psi - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2012, 06:49 AM
First and foremost I want to state that due to the rpm's I will be talking about we are diagnosing a boat engine.
SBC 350, 2 bolt main, stock re ring and bearing kit.
First and foremost, did I plasi gauge all of my bearings? Yes. NO doubts.
So here is what Ive got going on. I have an idea but want to compare it to what you guys think.
Running out on the lake at 2500 rpm's or less Im showing 40 psi and at idle Im showing 20 psi (here is where the fun starts). As long as I stay under 3000 rpm's my psi will stay in this range no matter what I do or how long I do it, from 5 min up to an hour (the longest I have tested my theory).
Once I romp on the ole girl (above 3000 to 3500 rpm range) the pressure still stays at a nice constant 40ish, but after a higher rpm run and pulling back down to idle I experience psi's of like 5. After that I can never get it to idle back up to 20 psi....... that is unless I take her home and put her up for the night, then the next day it starts all over again with the 20 to 40 range UNTIL I get above those magic numbers.
Its a re ring so I am running the 20-50 valvoline race oil. Im running a brand new HV oil pump (not high psi). Ditched the larger oil filter for a smaller car filter to hopefully keep more oil in the pan for circulation........ Delco filter. Oil has been changed since first start up.
Like I stated I have an idea of where I should be looking, but wanted a few opinions if you all would be good enough to give them to me.
P.S. I also ordered a new sending unit should be here this week. This is my #1 check. Im also going to put in a "T" and a mechanical gauge to double check my numbers.
But up till now this is what I have and this is what my delema is.
Thoughts?!
Old 09-10-2012, 06:53 AM
Also further information. This engine is a stock stock stock engine. It wasnt decked or bored, it wasnt squared, it wasnt even baked and cleaned. Make no mistake about it THIS MOTOR WAS CLEANED. Just not by a machine shop.
I threw a rod in my original engine. This is a block that was given to me in running condition. I put marine heads and cam in it and bearing, ringed @ gasketed the rest. Its to get me bye until I can build the Vortec block thats on the motor stand. Just couldnt stand the thought of going another complete summer without the boat.
Old 09-10-2012, 08:32 AM
lg1969's Avatar
Google "Tunnel Ram 406"
Replace is the distributor. It's not the shaft that drive the pump giving you problem, but the housing where the bottom part meets the block. If the distributor does not properly sealed you will loose oil in lifter valley. That is part of an oil passage.
I had to replace the distributor twice because of low oil pressure on my 307sbc and again on my 406sbc.
Old 09-10-2012, 08:46 AM
So you think the brand new billet aluminum Mallory distributor could be my oil issue?
Old 09-10-2012, 08:47 AM
do you have an oil temp gauge?
sounds to me its either building a bunch of heat in the oil and thinning it or possibly the relief valve in the oil pump is sticking after the higher rpm.
Old 09-10-2012, 09:27 AM
Oil temp no, but the pump is what im thinking. Head temp is 140 (regular marine temp)
Old 09-10-2012, 09:45 AM
Choctaw Bob's Avatar
Posible causes of varying oil pressure
1. Loose clearance on bearings. This description of good oil pressure cold low pressure hot is a common problem in high mileage/ worn engines. Try 20W50 oil if it comes up you can go to heavier straight oil.
2. Pressure spring in oil pump poorly heat treated. looses tension as it heats up.
3. Where is your oil pressure gage attached? Try the attachment hole beside the distributor in the rear of the block. Your bypass spring in the oil filter mount may be partially bypassing the oil to the filter and thus to the lower oil port on the block. try high performance filter like a Wix or K&N and block off oil bypass for full oil flow through the filter.
Old 09-10-2012, 10:00 AM
head temp really doesn't mean anything, especially on a marine engine where the entire lake is your radiator. oil pump is a fairly easy fix to try. we've had motors where the clearance was higher than we'd have like and will put a high volume pump in there. the theory being that its leaking more oil pressure out of the big bearing clearances than we'd like, so the extra volume will help keep the pressure up. i'd consider it a patch until you can fix it correctly.
an oil temp gauge would be a good idea too.
Old 09-10-2012, 10:09 AM
lg1969's Avatar
You will never Know. I had an Accel Dual point dis and it gave me low oil pressure until I replace it. It surprised me.
Old 09-10-2012, 10:18 AM
You may have too much oil in the pan. It may be getting churned up by the crank at higher rpms greating a lot of air bubbles in the oil in the pan which will reduce the oil pressure.
You might want to look at the oil on the dipstick after running at a low rpm and check for bubbles. Then do it again after running at 3500rpm and see if there is a difference? Might try dropping the oil level by a quart temporarily and see if it makes a difference.
Just a thought FWIW
ssmonty
Old 09-10-2012, 10:32 AM
Ill be honest, I was thinking oil pump release the entire time. There are a few other good points and I do appreciate the feedback. Not really looking forward to pulling the motor to change an oil pump thats one of the big reasons I threw this out there.
Thanks again all, and if anyone else has anything feel free to throw it out there.
Old 09-10-2012, 10:57 AM
Id like to know a little more about this oil bypass block off. This is something that can be blocked from an external point or are we talking directly on the pump itself?
Im trying to avoid pulling the engine. As described this motor is just to get me bye until I have one that is on the stand finished.
Old 09-10-2012, 11:10 AM
The oil filter bypass is in the plate the oil filter attaches to. You can by a plate without a bypass or block the stock one yourself. Just make sure you use high performance filters because sometimes cheap filters for chevys will blow up. Never a problem for fords cause they don't have a bypass.
Old 09-10-2012, 11:49 AM
I can't believe nobody has mentioned the HV pump. You are pumping all that oil right up to the top of the engine and it probably has had no drainback work done in the heads or the lifter valley. The fact that it's 20w50 only makes it worse-just returns to the pan that much slower. Under 3500 rpms may be the sweet spot where it just returns fast enough to be alright. Over that, and it doesn't come back to the pan fast enough.
As far as any pressure issues, they're fine up to when the problems start. If your clearances were fine on a stock motor, I would run 5w30 or 10w30. Just a rering and good clearances wouldn't dictate thicker oil. But verify that you have a good gauge as mentioned and a good filter (like Wix)-not Fram. Not sure about the delco, but the smaller one is probably hurting you here.
Did you verify the pickup to the pan clearance? If it's too low or too tight to the sloped up part of the pan sump, the pump will cavitate and not be able to pump oil at a certain rpm. In that case, though, the pressure usually comes back as soon as you let off the throttle.
Old 09-10-2012, 02:15 PM
Just to clear up a few things and possibly unearth whole new questions,
#1 I was running 10w30 at original startup and break in. Had the same problem as with the 20w50. I went with the valvoline 20w50 for the zddp for the flat tappets.
#2 even if we stop and swim for 15 min the psi still acts funny (which would make me think its not the oil not returning to the pan). Only after sitting overnight does it run in normal range again. Also, its a ski boat and there is a pretty big angle at which the engine sits. Dont think oil can sit up in the heads so much, it all runs to the back of the head pretty quickly (found this out while adjusting the valves with cut off V.C.'s). Also after returning to over 2000 rpm's the pressure is right back up to 40 psi which would indicate there is plenty of oil in the pan, only after dropping to idle does it drop out to nearly nothing.
I am in no way "trying" to discredit what you are saying and I appreciate the feedback, but these are the reasons Im not certain if what you are thinking may be exactly right.
low oil psi on sbc sweet85chevy Engine 7 02-21-2011 11:14 PM
80+ psi oil pressure: Harmful? QParker Engine 19 01-30-2011 06:49 PM
oil psi scare runn141 Engine 17 06-04-2010 05:30 PM
elect. oil psi gage rick laplante Electrical 4 06-08-2008 01:18 AM
oil psi relief valve Snick Hotrodders Site Suggestions and Help 1 06-16-2006 12:17 AM
