oil psi relief valve - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders Site Suggestions and Help
Old 06-16-2006, 12:45 AM
does any one know what the psi is for the pressure relief valve on a small block Chevy is
Old 06-16-2006, 01:17 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Yu are in the wrong forum for your question. To get more exposure to your question repost it in the engine forum. Give the guys there a lot more information on exactly what engine you are talking about. I assume you are talking about the oil filter pressure relief valve although some older non filter equipped engines just used a valve in the block. A normal modern engine is around 60 psi; although older engines may be less or more? Here is link about every thing you always wanted to know about oil filters:
http://www.greenmediaonline.com/uplo...lk/0604_st.asp
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Synthetic Motor Oil In 454 Rebuild leejoy Engine 36 11-20-2006 03:34 PM
2 Valve Relief vs. 4 Valve Relief Chevy21 Engine 4 12-02-2004 02:07 PM
Valve lash and oil pressure question Jag Daddy Engine 4 07-17-2004 10:33 AM
oil pressure! motor new, start up 75 lbs ! now1lbs at1400 rpm wantafastpass Hotrodding Basics 6 02-29-2004 12:54 PM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
