Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Which Oil Pump
Thread: Which Oil Pump
Old 03-06-2013, 02:33 PM
ap72 ap72 is offline
Banned
Originally Posted by daveh View Post
Thanks guys from all of the replys it sounds like I should go with the Melling standard volume pump below since the 340 isn't built over the top. All I know from the previous owner is that it's punched out 30 over with a purple cam and forged pistons. Looks like standard rockers nothing special.
Melling Oil Pumps M-72 - SummitRacing.com
Dave
high volume pumps are for low rpm protection, not high RPM.
Once the bypass opens the high volume will flow no more than a standard pump- BUT below it (lower RPM) you will have more flow and pressure. I like them for street cars especially ones that have shallow gears (low rpm most of the time).
High volume pumps work well at lower rpm, but at higher rpm the standard pump actually works better- where the crossover is depends on clearances, oil viscosity, temp, and your relief spring pressure.
The Following User Says Thank You to ap72 For This Useful Post:
malc (03-06-2013)
