Oil Pump Bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2006, 07:44 AM
Oil Pump Bolt
What's the size of the bolt used to bolt the oil pump on the block for a chevy 350 engine?
Old 03-02-2006, 08:05 AM
bondo's Avatar
3/8thsX16......... I'm not Sure of the Length,....... 1 1/2" I Think........
Old 03-02-2006, 08:39 AM
Choctaw Bob's Avatar
Length is 2 3/16" on a 327 which should be the same
Old 03-02-2006, 11:37 AM
Thanks
That's what i grabbed to try. So at least i ain't lost my mind.
Thanks for a quick response!
Old 03-02-2006, 11:49 AM
You are lucky I had an engine on a stand with the pan off so I could pull the bolt and measure it!
Old 03-02-2006, 03:58 PM
RPM's Avatar
RPM RPM is offline
World Class ASE tech
I am pretty sure that is a 7/16 bolt.
Old 03-02-2006, 04:24 PM
King of my Man-cave.
Therer are 2 different bolt lengths for the SBC oil pump bolt (7/16" diameter, coarse thread), 2" and 2 3/8". Don't use a short SBC head bolt!
tom
Old 03-02-2006, 06:46 PM
Marcel
Last journal entry: Choo-choo town
bolt sizes
divide the head size by 3 and multply by 2. If its and indust. bolt subtract 1/8 before diven. 3/4 head*3=1/4x2=1/2
7/8-1/8=3/4*3=1/4x2=1/2 on indus.
read the tool and rember where the cali. is .
Old 03-02-2006, 07:49 PM
tom
My example came from an engine I didn't assemble last time so who knows if it is right.
Old 03-03-2006, 05:35 AM
Marcel
bolt sizes
Well I still don't understand how a 3/8 bolt in a 7/16 hole could hold an oil pump on?
Old 03-03-2006, 06:00 AM
engineczar's Avatar
tom
Read Tom's post, it pretty much covers it all.
Old 03-03-2006, 06:05 AM
Son of a buck
That's what i tried and apparantly the dang thing is stripped. This is the only thing keeping me from finishing this project. Any thoughts.
Old 03-03-2006, 06:32 AM
tnsmith10's Avatar
when will it rain???
its more than likely a 7/16 x 14 bolt... from what it seems, ur trying to use a 3/8 x 16... try a bigger bolt
Old 03-03-2006, 06:33 AM
engineczar's Avatar
The bolt is stripped or the cap?
If it's the cap is it all the threads or just the first few? If it's just the first few then you need a longer bolt just make sure you don't go too far and bottom out the bolt which leads to a loose leaky pump.
Old 03-03-2006, 06:59 AM
RPM's Avatar
RPM RPM is offline
If you use too long of a bolt it could hit the back of the main bearing. That would cause a major engine failure for sure. If you can't find the right bolt ARP has them and the local speed shop should have it.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
which oil pump for a 406? high volume or high pressure? 406 ss monte Engine 23 09-10-2006 07:48 PM
Oil pump ? 70gmcer Engine 9 11-20-2005 01:01 PM
SBC oil pump shaft Richs66chevelle Engine 6 10-30-2005 12:19 PM
351 windsor oil pump bolt size 72Bronco351 Engine 0 11-20-2003 11:54 AM
