Oil Pump Bolt Big Block Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2009, 10:55 AM
I am assembling a BBC engine and need an oil pump bolt. My books indicate that it is a 7/16 - 14 bolt 2 inches long. Can I get a grade 5 or better bolt from Home Depot to use or do I need to order one from somewhere? If I use the Home Depot bolt, do I need a flat or a lock washer?
Thanks!
Old 09-09-2009, 01:31 PM
Buy one from ARP or somewhere.
The grade 8 may be strong enough, but it does not have the
correct shoulder on it that a proper oil pump bolt does.
Old 09-09-2009, 02:53 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'd hook up w/a stud and nut from ARP- they're sold by every speed shop out there, cost a pittance and will do the job quite nicely for you. All the h-ware needed is included- along w/instructions.
Nothing particularly wrong w/an ARP or OEM bolt, either- but don't use HD hardware in the engine.
Old 09-09-2009, 08:12 PM
thanks guys! will do.
Big block pil pump on small block Chevy dallam11 Engine 22 03-24-2012 07:36 PM
Oil Pan Help Big Block Chevy 454 71 nova Engine 0 08-18-2008 09:51 AM
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
Oil Pump Bolt scbauml Engine 18 03-09-2006 11:03 PM
s/b chevy oil pump.....how do i..... fitzwell Engine 1 01-09-2006 05:20 PM
