Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil pump bolt pull out
Old 08-12-2010, 12:44 AM
Micheald1 Micheald1 is offline
Ok so I am slowly rebuilding my first engine, a basicly stock 454. I am at thr point of mounting the new oil pump and the retaining bolt "pulled out" ot the top of the rear main cap. It looks to have only gotten the top 2 threads. Apparently the new pump has a shorter mounting height and I did not check this. There is now a small "crater" on the top of the threaded hole. Is this some thing i should worry about or can I put a stud in and not worry so much?
Thanks for any advice.
Mike
ID:	47346   Click image for larger version
Name:	oil pump chip 004.JPG
ID:	47347   Click image for larger version
Name:	oil pump chip 005.JPG
ID:	47348   Click image for larger version
Name:	oil pump chip 001.JPG
