Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil pump bolt pull out
Old 08-13-2010, 09:13 AM
muddi1's Avatar
muddi1 muddi1 is offline
Originally Posted by AndersonRacing44
its good that you got a bolt in there but it would be better if you got an ARP oil pump stud, that is the common fix for problems like this.
I am aware of ARP studs but am not convinced that they are any stronger than a grade 8 bolt. Plus the local speed shops want $$$$$ for them and this cost me a total of $2.38 after a 9.9% tax rate. I know I get what one pays for but $10+ for an oil pump stud is a bit steep IMO..
Thank you for the advice, should I have any issues with the locktighted bolt I will pick up an ARP stud kit.
