OIL PUMP CLEARENCE to strap bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2011, 04:04 PM
I Bet this topic has been covered many times , but im unable to find the info ,I have a prepared SBC block that has the rear main cap Strapped, and the oil pump will need grinding to clear the main bearing bolt/stud nut,But before I put the Dremel to it , I wondered was there any other solution IE. a metal spacer beneath the pump body?, the sump im using would allow this.but then the oil pump drive would need extending,maybe a longer one is available?
Old 04-29-2011, 05:27 PM
v8hed's Avatar
AK427
Nothing wrong with clearancing the housing... here's mine after I clearanced it:
Old 04-29-2011, 05:50 PM
Hi Thanks for input, I can see you application is a bit different to my build as the photo shows,In order to fit my pump with the "Strapped " rear main bearing cap, I will have to grind a much larger chunk from the pump body , probably three times as much as your engine needed , maybe more.Im a bit nervious about weakening the pump body , also if I break into the body its scrap.So I am hoping someone with the same combo. will guide me.
Broke Strap Bolt V8 Super Beetle Transmission - Rearend 6 02-17-2010 03:48 PM
missing ground strap- Can it cause a backfire? Chevy350Sb Engine 3 11-29-2009 05:32 PM
ground strap over thinking tomthecomic Electrical 1 08-12-2007 08:17 AM
Door Check Strap - Options? Houston54 Body - Exterior 4 07-30-2006 06:50 PM
Braided Grounding Strap 58Chev Electrical 9 02-13-2006 06:11 PM
