oil pump gasket - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-23-2006, 12:01 AM
say10tatoo's Avatar
New Member
Last journal entry: Motor In
oil pump gasket
is there a gasketon a mid 70's chevy big block oil pump
Old 04-23-2006, 05:45 AM
Guy Hiltz's Avatar
oil pump gasket
There is no gasket but the How To Re-build BBC book says to run a thin bead of non-hardening sealer around the pump mating flange on the rear main bearing.It also says not to use RTV,also use it sparingly,you dont want to block oil flow.
Oil Pan Gasket Chevy21 Engine 5 03-02-2005 09:15 PM
New Cam Install - Oil pan gasket info requested. Siggy_Freud Engine 5 12-17-2004 11:00 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
SBC High Volume Oil Pump 360Camaro Engine 4 08-18-2003 11:43 PM
oil pump priming MardyMar Engine 1 05-03-2003 03:46 AM
