Oil Pump pick up clearance - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2011, 10:48 PM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
What is the rule of thumb clearance between the oil pump pick up screen and bottom of the oil pan? Street car and occasional drag racing.
Old 03-12-2011, 10:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
3/8" is what I have always used. A little more or less is OK.
There's a video by Melling that explains how to measure for it and adjust the angle of the pick up to obtain the correct clearance.
Note that the measurement is taken NOT from the very bottom of the OEM-type screen assembly- but from the ledge closest to the screen itself! This is important and hard to explain w/o diagrams or photos/video.
Old 03-13-2011, 08:08 AM
1930u's Avatar
Thanks...watched the video.
Old 03-05-2012, 07:41 AM
Thanks , I have seen the video and read others input on the issue and was still confused on the clearence. 3/8 from the middle of the pump or 3/8 from the tip?
Old 03-05-2012, 08:07 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It should be fairly close to the same from the front to the rear of the pick up screen assembly unless you have the pick up screen tipped quite a bit. If you have to tip it so much that you're seeing a >/= 3/16-1/4 inch change front to rear for example, the pan needs to be clearanced so the PU can be positioned level or a shorter pick up used. Clearancing the pan is a fairly common occurrence when using a HV pump- which in most cases really isn't needed in the first place.
distributor to oil pump shaft clearance CosmikDebris Engine 4 01-22-2011 06:41 PM
Oil Pump Pick up Tube Install SBC... Caballerokid Engine 20 10-05-2010 07:10 AM
Oil Pump Pickup Clearance V3500 Engine 10 09-08-2009 09:43 PM
Oil Pump Pick-Up ezobens Engine 3 03-20-2006 08:23 AM
oil pan/pump pick up clearance thumbsUp Engine 1 08-01-2003 08:08 AM
