Hi,
I've always tacked them, but I suppose you could drill & pin it, just don't braze it. Rich |
Ya, the tack thing didn't work so well in this case. I ground the weld all off and am starting over. I can't imagine I HAVE to do anything with it, but I would really like to just to be safe. I just think tack welding it is out.
Well you could make & fit a brace, that is, bolt one end of brace to the pump housing & tack or braze the other end to the pick-up tube.
Rich |
These bolt to Pump & clamp to Pickup tube>> http://www.northernautoparts.com/Pro...tModelId=12738
The thing is, the pick up has to be new to properly press fit into the pump body. If you weld, you should remove the pressure bypass spring and piston. Some guys will disassemble the pump to weld on it- I feel this may invite warpage. But that should be checked for if any welding is done, apart or assembled, IMO.
My favorite solutions are either the use of a retention bracket or the purchase of a Melling pump that bolts the pickup tube on similar to what Ford does. Frankly I never, ever take a torch to an oil pump casting. Others do, I won't! http://www.jegs.com/i/Melling/689/10552/10002/-1 http://www.jegs.com/i/Melling/689/10555/10002/-1 http://www.jegs.com/i/Melling/689/12559/10002/-1 Problemo solved without resorting to Mickey Mouse methods. Bogie PS; be sure to drill the bolt heads and run some safety wire thru them. Last edited by oldbogie; 09-30-2010 at 12:45 PM. Reason: safety wire |
Both pumps are said to have "25% longer" gears, one has 10% more volume and the other has 25% more volume than a stock pump. Less teeth?
I don't know about Disney characters , but the least preferred method for retention of the pick up- for ME- would be any of the "added afterwords bolt-on retainer" affairs (bolts to the cover AND bolts to the tube):![]() I don't weld/braze either- but there are many thousands of them in service as I type, so I'm sure it's not the kiss of death- as long as the relief spring and piston are removed. And replaced! Milodon and Moroso make press-on tubes w/an additional bracket welded to it that's bolted down w/a cover bolt, works on press-on pick up-type oil pumps (the ones that don't cost $90-$100 for the pump and PU). |
I appreciate all the good info here. I ordered the bolt on bracket and am going to give that a try. I'm also thinking I will pick up a new pump/pickup since I didn't disassemble the pump before tack welding. But I do want to point out I did just that, tack weld. It wasn't like I was running a bead all the way around it. When I was done, I did notice that the pump body was hot/warm. So to be safe since I've been so safe thus far, I will just purchase a new one. Eff it, lol.
I pull the cover, remove spring and bypass valve, and braze a 3/16" long tack using a sharp acetylene flame and brass rod, only takes 15-20 seconds. Never have had one come off, or a pump pressure problem. Let air cool and reassemble I've done them completely assembled with a TIG welder, where you can realy control the heat, hot quick tack and done in 5-7 seconds, no problems there either. |
You can weld it on. You need to know how to weld something thin to something thick. Remove the cover, the spring and bypass from the pump so you don't damage those. Turn your welder to an amperage that'll penetrate the pump casting. Start your weld on the casting next to the tube and let a puddle begin. Then move it to the pickup tube just for a split second and back to the casting. The key is to weave back and forth only slightly touching the pickup tube so you don't blow through it. You don't want to attack the casting and tube at the joint at the same time otherwise you'll blow through it.
So there you have it:
A total consensus...
It's not the cleanest tack welds but the pick up tube is not going anywhere.
I never has a pick up tube come loose from tack welding it on.
| Oil pick up tube | truckboy61 | Engine | 6 | 08-13-2010 06:49 PM |
| anyone have problems sucking oil pan dry | willis 77 | Engine | 14 | 08-09-2010 05:08 AM |
| What oil pump would be good for 350 SBC? Heard bad news about melling | eric32 | Engine | 11 | 02-15-2009 02:48 PM |
| sbc oil pump drive | nettio | Engine | 2 | 02-02-2006 03:19 AM |
| Excessive oil under valve covers in SBC? | TVR383 | Engine | 13 | 11-21-2005 12:48 AM |
