Oil Pump Pickup Clearance
I have some questions on sbc oil pump pickup clearances. I have 2 pumps with 2 different pickups. The first is the m55, and the second is the m55hv. The m55 was supplied by the machine shop with the pickup already installed. The problem with this pump, is that the bottom of the pickup hits the pan. I have checked with the gasket in place and it still hits. Its parrel to the block too. It would probally work but the pickup screen would be less than .200 off the bottom. The secong pump I bought was the m55hv (local parts store) with the recomended pickup. The problem with the one is that I have rock the pickup alittle to get the screen of pickup to 1/2" clearance (it would be close to 3/4" clearance if it was parralel to the block. Is this ok? Any other suggestions? The oil pan is stock and is 7.5 inches deep. I wanted to go with the high volume because I dont know what the engine clearances are, and I run an external oil cooler. Thanks again for all the help guys and or gals.
I disagree, 3/4" is way too far away. I would never run more than 1/2" and that is pushing it, 3/8" would be ideal. I'm not afraid to tip it some to get it closer to the pan bottom, it is being tipped in the right direction compared to the opening.
Agree with Eric, always shoot for 3/8". I have also run 'em as close as 1/4" and they were fine.
I agree with the 3/8...
Eric has my vote also 3/8.,,,,,,,,,,,,,,,,,,,,,,,,,,,Cole
Thanks for the replys. Just what I thought, but I thought I should ask. I will tilt it alittle then. How important is it to weld the pickup. I have got it in the pump pretty solid, but its not welded. I tried on the m55 pump to weld (with a habor freight special welder) but the splatter got me nervous so I didnt on the m55hv. Isit fine just pressed in, or should I take it to someone who can braze it? I'm learning alot, thanks much for the help?
If I don't braze it, it gets locktite on it if it doesn't have a bolt-on leg(Moroso/Milodon type). I have also made a leg using 12-14 ga x 1/2" strap to go from the bell to a pump body bolt. Make sure it clears the rotating parts and has a good sized foot to eliminate cracking where it is welded to the bell.
There is also a bolt-on failsafe retainer made for stock pick-up tubes, I don't remember who makes it but seems like S-10 Racer mentioned it recently (today?) in another thread. |
Thanks for the replys. If I tilt the pickup I think I can get to the 1/2" mark. Actually alittle less than 1/2". i just wanted to make sure it was ok to tilt it alittle. Would you guys recommend something like this?
http://www.summitracing.com/parts/SES-3-60-08-037/ Thanks for the help. |
You should be OK with it..
| Trouble with oil pump | trblmker | Engine | 6 | 06-23-2009 04:04 PM |
| Chevy Small block, low oil pressure and ticking? Help.. | Bowtie_Boy89 | Engine | 2 | 02-25-2009 03:52 PM |
| 305 Chevy oil pump pickup replacement | 1940 Ford | Engine | 1 | 12-20-2008 01:05 PM |
| 1968 - 1969 YW block. I can't find a DISTRIBUTOR that fits the oil pump shaff | Bryan Meier | Engine | 5 | 06-16-2008 10:15 PM |
| Chevy Oil Pickup Installation Question | leejoy | Engine | 13 | 02-11-2008 02:17 PM |
