Oil Pump Pickup Tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2011, 05:57 AM
I installed my pickup tube on my std volume oil pump last night (sbc 350). After I installed, I realized it hit the pan, so I twisted it in the pump to fix it. I was careful and did not dent the tube or distort it in any way.
My worry is that after I came in for the evening, I was watching an installation video put out by Melling. The guy in the video says never to twist the tube in the pump once it is installed (This info would have been good 20 minutes earlier....my usual mode of operation!!)
So, have I destroyed my seal between the pump/pickup tube and it will leak now? Can I just pull out pickup tube and install a new tube, or will I have to replace pump and tube?
Thanks all.
Old 01-04-2011, 08:38 AM
bondo's Avatar
Ayuh,... I don't think you've hurt it, but I'd throw a tack weld or 2 on it...
Old 01-04-2011, 08:41 AM
delawarebill's Avatar
oil pump
its a pressure fit and not an o'ring fit... but i would also tack it too...
Old 01-04-2011, 09:14 AM
Wiki Edits: 49
As long as you didn't kink the tube when you twisted it you should be fine. And yes, throw a tack weld on it to keep it from moving or coming loose from engine vibration.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
Old 01-04-2011, 08:29 PM
Thanks for the reply guys. That makes me feel better! I plan on welding it in place.
aftermarket pickup tube installation dirtinla Engine 1 11-29-2008 06:08 PM
little plastic tube that came with my melling oil pump? darkostoj Engine 7 12-31-2007 11:43 PM
Checking the pickup tube? HemmiGremmie Engine 5 03-10-2006 09:39 AM
pickup tube wont fit in pump Johnn Engine 11 04-26-2005 12:12 AM
Oil Pump Tube S10Fan Engine 5 03-07-2004 05:59 AM
