Oil Pump Priming - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2010, 07:23 PM
Oil Pump Priming
I tried priming the oil pump on my 350 today and I don't know if I have a problem or not.It's on the stand,filled it with oil and rented a priming tool from Autozone.I started the drill slowly until I felt some resistance and started giving the drill some more juice but it seemed to be getting harder for the drill to turn so I stopped.I pulled the tool a stuck in a screwdriver and tried to turn the pump,it turned but somewhat hard.I let it sit for a while and went back and it was much easier to turn.I expected to see some oil come up through the rockers but I didn't also one of the reasons I stopped priming.I didn't have an oil pressure gauge hooked up so I'm not sure if It getting any.
I know it has enough oil in it,I double checked the pickup height when put it together and I had the drill going the right way.Should I pull the pan and the oil pump and check it,or put a gauge on it first and try it again.How long should it take for pressure to build.I as using a 3/8 drill should that be strong enough for the job.
Old 12-17-2010, 07:35 PM
oil priming
On this problem i hope your using an electric drill ,i would try it again you have to remember that the oil has to go thru the dry lifters and the in them.
DoubleVision's Avatar
It`s supposed to be hard. It`s trying to squeeze oil through passages that are about .002 of clearance on the rod and main bearings. That`s where the
"pressure" in oil pressure comes from. If the pump just free spun but still pumped some oil then you`d have a problem.
Old 12-17-2010, 08:02 PM
1badLemans's Avatar
I just primed my chevy engine 2 weeks ago and you have got to use a heavy duty drill, not a wimpy one because it will not spin enough to get oil to the rockers and might burn up the drill. Use the tool and do yourself a favor and buy a 20 dollar oil pressure gauage or a 30 dollar oil/temp/voltage guage set. Very easy to install and you want to make sure what your pressure is at with a brand new engine you spent so much money on. The drill I used was a beefy hammer type that pluged in to an outlet and it had plenty of torque and rpm to get to the rockers. Also spin the engine some by hand to get through all of the passages.
Old 12-17-2010, 08:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Use a decent 1/2 inch electric drill thats what i alway's use, As do most people.
Cole
Old 12-17-2010, 10:39 PM
i darn near cooked my 3/8" craftsman drill priming a motor.. it was getting hot enough to smoke... use a compressed air drill if you have one.
remember you _HAVE_ to turn the crank while priming, or only half the engine will get oil!
Old 12-18-2010, 11:33 AM
A 3/8's home utility drill does not have the kahunas to run a Chevy oil pump. This needs at least 1/2 inch chucked, contractors grade drill motor. It is likely you won't get oil from some push rods and perhaps none at all from the passenger side. Rotating the engine with a wrench in it's normal direction of rotation is necessary to operate the lifter's internal valves that allows oil into the push rod.
Bogie
Old 12-18-2010, 04:28 PM
a 3/8" home drill can do it.. but it's very hard on the motor and it gets HOT FAST
i agree however.. a bigger 1/2 drill is the way to go.. I usually use my 240v hammer drill with the hammer turned off.. but last engine I primed, 240v wasn't available.
Old 12-18-2010, 05:51 PM
Oil Pump Priming
Update
I hooked up an oil gauge this morning and gave it another try.Oil started to flow and I got to about 20 psi before my 3/8 drill got so hot I couldn't hold it anymore,it was smoking.Went down to Harbor Freight and got a 1/2 drill.No problem this time,got 50 psi and oil coming out of all the push rods on both sides but more it seems on the left than the right,it wasn't shooting out but it was flowing.I didn't rotate the engine,I have all the spark plugs in and I didn't want to bust the balancer bolt.I'll pull the plugs and prime it again
Old 12-18-2010, 06:32 PM
techinspector1's Avatar
Wiki Edits: 326
Does the priming tool look like this?
http://performanceparts.com/part.php?partID=88439
Old 12-18-2010, 07:17 PM
Oil Pump Primer
Yes thats what I'm using
Old 12-18-2010, 08:12 PM
it's important to have that collar on it.. that's necessary to seal the oil gallies in the small block.. if you don't, it will never pump oil to the top of the engine.
Old 12-18-2010, 10:16 PM
Oil Pump Priming
Yes I have the collar on,I'm getting oil to the top with about 50-55 psi.
Old 12-18-2010, 11:05 PM
sorry.. didn't mean to imply you didn't.. that was just more a general observation then anything. sounds like you got the whole thing under control.
high volume and high pressure oil pumps can destroy cam and distributor gears! Knobie Engine 75 02-13-2011 02:22 PM
Melling M155HV Oil pump? mrdreex Engine 34 06-26-2010 07:18 PM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 07:39 AM
oil pump priming problems yodert75 Engine 1 05-28-2008 10:38 PM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
