thanks trees had step away for a moment back to the beging I am priming the oil pump on 327 the intake is not installed yet an I am using a oil pump priming tool when i start running the drill oil is only coming out of about two of the rockers all of the oil is coming out around the top of the priming tool i installed a high volume oil should the pump be pushing oil out this way or should it be push oil out of the 16 rockers
