Oil pump question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2011, 10:01 PM
Oil pump question
I was trying to swap to electronic ignition in my 63 galaxie and while pulling the old dizzy the oil pump shaft was stuck so when I pulled the clip fell off. I raised the motor some got the clip and was wondering if I need the clip on the oil pump shaft? And should I replace the gasket? The tranny is barely hitting the firewall and I was unable to get the pan off.
sbc oil pump question sprocket Engine 5 02-25-2011 09:06 AM
Oil pump question 92 sbc Eric64 Engine 3 06-07-2007 05:14 PM
Gas at the pump question? dbdbb Hotrodders' Lounge 14 02-15-2007 09:31 AM
Another Oil Pump question 35WINDOW Engine 4 10-27-2006 10:26 AM
Air Pump Question Jag Daddy Engine 1 06-11-2004 01:13 AM
