oil pump screen install - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2004, 09:00 PM
jrm123180's Avatar
A Learning Hobbist
How do I install an oil pump screen/pickup? its for a '79 350sbc.
I got the tool at the auto store, but I can't figure out how to use it, there's not instructions. Any help would be appreciated.
Thanks,
Steve
Old 09-07-2004, 09:03 PM
sbchevfreak's Avatar
Licenced Automotive Technician
tool? i wish! i've never even seen one! could you post a pic? i usually use an open end wrench and a hammer, then a small tack weld to be sure!
Old 09-07-2004, 09:12 PM
jrm123180's Avatar
A Learning Hobbist
I thought about a tac weld, but i'm wasn't sure if it was aluminum or not. I was going to try that. Thanks, i'll do that.
Steve
P.S. You can find a pic here.
http://www1.autozone.com/servlet/UiB...p/oil_pump.jsp
Old 09-07-2004, 09:17 PM
all the tubes i have used were steel. good luck!
Old 09-07-2004, 09:28 PM
jrm123180's Avatar
A Learning Hobbist
great, thanks
Old 09-08-2004, 04:53 AM
302 Z28's Avatar
If you use a tack weld, be sure to remove the pump cover from the pump when welding on it.
Jegs sells a sheet metal device that secures the pump pickup without having to weld on it.
Part #555-23620 $8.99
I have never liked welding on the pump.
Vince
Old 09-08-2004, 07:25 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
I don't think that tool from auto zone will work on a GM oil pump.
I tac mine.
Troy
