oil pump screen installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2007, 03:06 PM
i bought a melling high volume pump along with a steel sleeve and pin driveshaft along with the new screen.
i can`t seem to find how to get the pump screen into the pump housing. Anysuggestions? i had a lil tip i thought was bogus. boil it in oil.??
Old 04-15-2007, 09:26 PM
BOBCRMAN@aol.com's Avatar
Without buying the install tool. Line up the pickup with the inlet hole. Take a snug fitting open end wrench and run the flat sides up to the raised stop on the tube. Then carefully tap the tube into the pump housing using a small hammer on the flats of the wrench. When seated all the way in and at the proper angle, spot weld the pickup to the pump housing.
Old 04-16-2007, 12:54 PM
runn141's Avatar
SB S10
i heard that you can put the pickup in the freezer overnight and it'll fit easier
Old 04-16-2007, 02:55 PM
68NovaSS's Avatar
Wiki Edits: 9
I've done the freezer action, it works but you need to be fairly quick, it warms up retty quickly. Same technique I've seen used for hardened valve seats.
Old 04-17-2007, 10:10 PM
IT worked! @_@ Thnx,
Now i`m making some progress with this build. Apreciate it.
Old 04-17-2007, 10:13 PM
Get a pickup that has some way of holding itself on to the oil pump, chevy pickup sometime work they way back out of the pump
Old 04-17-2007, 11:30 PM
texastomeh's Avatar
I can personally vouch for the method that BOBCRMAN described.
I just recently did the same install on my SBC 405. Worked slicker than owl doo!
texastomeh
Old 04-18-2007, 06:06 AM
302 Z28's Avatar
After you install the pickup, install one of these .
A buddy of mine holds the patent on it.
Vince
Old 04-18-2007, 10:55 PM
texastomeh's Avatar
That's a neat widget 302/Z28!
The MELLING HV that I recently installed had a "factory" version of essentially the same thing already attached to the pickup tube. After installing the tube in the pump body, you use two of the pump base plate bolts to attach it and hold the whole thing in place. NEAT!
However, being an "Old Dog", I still tacked a little spot at the tube/pump juncture like BOB said above. Why? Because old habits die hard and also because I paid good money for this welder and I intend to use it every chance I get!
texastomeh
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 05:03 AM
high volume and high pressure oil pumps can destroy cam and distributor gears! Knobie Engine 75 02-13-2011 02:22 PM
chevy 350 oil pump priming noise? chevymastermind Engine 12 04-10-2007 04:04 PM
high volume oil pump question jstaten Engine 4 01-15-2006 11:56 PM
oil pump priming MardyMar Engine 1 05-03-2003 03:46 AM
