oil pump shaft installion - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2009, 11:02 AM
I purchased a new oil pump and the shaft for my sbc 350. I'm using an ARP high performance oil pump shaft and want to verify that it does not lock into place before I put my pan back on. The factory one has the plastic sleeve and this one is metal.
Old 09-29-2009, 12:25 PM
engineczar's Avatar
The aftermarket shafts with steel sleeves do not lock onto the pump.
BSE Racing Engines
Old 09-29-2009, 12:35 PM
The GM intermediate shaft isn't designed to be locked into place in the sense that Fords are if you remember to put the spring washer on the hex shaft.
Whatever hold you get on the Chevy is one of luck, so if your's fits a bit loose, you don't want to turn the engine upside down without a distributor in it to hold the shaft positively in place. An assembly trick is to coat the inside of the sleeve with fiber style wheel bearing grease, it's sticky stuff and usually provides enough goo to hold the parts together if the engine gets flipped over during assembly without anything to clamp the intermediate shaft positively in place. However, if it falls out and the intake is not in place it's no biggie as it will reinstall from the valley side.
The steel sleeve is goodness as it doesn't get hard over time and crack away leaving the intermediate shaft without a supporting connection.
Bogie
Old 09-29-2009, 12:57 PM
302 Z28's Avatar
The OEM plastic sleeve serves no purpose other than to hold the OEM intermediate oil pump shaft in place while the block is upside down being assembled.
Vince
Old 09-29-2009, 07:07 PM
tnsmith10's Avatar
when will it rain???
i have the same oil pump shaft in my engine and like engineczar said, it does not lock onto the pump. also, with the taper at the pump end, it wont fall through the engine when turned upside down.
Melling M155HV Oil pump? mrdreex Engine 34 06-26-2010 07:18 PM
Possible oil pump failure sbc eric32 Engine 12 09-09-2009 07:00 PM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
Oil pump drive shaft cdiedrick Engine 2 08-24-2005 06:17 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
