Oil pump sieze - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2009, 01:31 AM
fourby2's Avatar
is a lump of wood.
Last wiki edit: Identifying Fords
Oil pump sieze
I bought this new old stock short motor. 302 windsor with its stock oil pump.
Anyway put it in my old truck got about 10,000 km them the oil pump siezed up and snapped the dizzy drive pin.Now this engine never ran low on oil , pickup seems fine.Any way put another mellings pump on to replce failed one and havnt had a problem since.Pulled pump apart no phsical evidence of rotor problem etc.The bush/bearing seized solid.Anyone else seen this, more improtant what caused it?
Old 06-12-2009, 04:17 AM
riceharvester's Avatar
I've heard of metal shavings getting sucked up and causing this...
Old 06-12-2009, 06:27 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by fourby2
the oil pump siezed up and snapped the dizzy drive pin. *snip* Anyone else seen this, more improtant what caused it?
Not quite the same thing, but I had a 351C twist the pump drive about two revolutions when a TINY piece of gasket material (that must have gone up inside the oil supply bore of the block when the old gasket was removed) wedged between the rotor and housing.
I was rather surprised that a piece that small would seize the pump- but it did. Had it been a different design (spur gear-type as opposed to a gerotor) it wouldn't have done that.
Oil leaking near fuel pump..what the heck??? HotRodF100 Engine 13 01-08-2012 06:03 AM
1968 - 1969 YW block. I can't find a DISTRIBUTOR that fits the oil pump shaff Bryan Meier Engine 5 06-16-2008 11:15 PM
Yet another problem, oil pump shaft..... sexypizzaman Engine 8 06-13-2008 06:19 PM
high volume oil pump question jstaten Engine 4 01-16-2006 12:56 AM
distributor gear / oil pump rod issue?? bskaggs Engine 8 06-11-2004 09:02 PM
