Oil Pumps - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2006, 01:54 PM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Oil Pumps
Ok, you all know I'm building a new 350. I'm just about to install the new oil pump in the block and have a question for the veteran engine builders out there, do I pack the inside of the oil pump with vasoline like I have read in the magazines or not?
Thanks
Old 03-05-2006, 02:01 PM
poncho62's Avatar
Wiki Edits: 5
No....But prime the pump before startup.
Old 03-05-2006, 02:11 PM
The Big Money
What would happen if you did pack it with vasoline?
Old 03-05-2006, 03:05 PM
Nothing, it's just not common practice anymore. Priming the oiling system is now the accepted practice.
Old 03-05-2006, 03:25 PM
poncho62's Avatar
Wiki Edits: 5
I would be worried about clogging something up..............
Old 03-05-2006, 03:56 PM
BOBCRMAN@aol.com's Avatar
The old vasoline trick was used mostly on engines that had remote pumps and were hard to prime. Such as the old Buicks, with pump in front cover and terrible oiling systems.
A Chevy pump is submerged in oil.
Old 03-06-2006, 07:53 PM
Tominator's Avatar
Although it is an old way to prime the pump, ANY grease will serve to get rid of the air in the pump and draw oil sooner and even if you prime the oil system getting rid of the air in the pump will make the process of getting oil to the bearings easier.
Old 03-06-2006, 09:59 PM
GoneNova/406's Avatar
i've seen them do both on the car shows on t.v. many times.the worst that could happen is you change oil after fire up which most people do anyway.
Old 03-07-2006, 12:34 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
On old-style filters it wasn't much of an issue, but today's modern filters it can clog it pretty quickly. The bottom line is, if you prime the pump before startup there is absolutely no need for grease in the pump. None. Just prime the pump for a while and then start it. No need for grease at all.
Help me figure out where my Oil is going :( Malibu73 Engine 22 02-21-2006 12:21 AM
Titan oil pumps Fastnuf Engine 1 04-27-2005 04:18 AM
Oil pressure loss SB Chevy Finmike Engine 30 06-12-2004 11:27 AM
Oil pumps on 235 Chevy 6s willys36@aol.com Engine 0 08-15-2002 06:51 AM
oil pumps truckin chuk Engine 4 03-22-2002 05:22 PM
