Oil Pushing up thorugh breather - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2008, 04:56 PM
Regal Beagle's Avatar
I was out cruising yesterday and could smell oil buring under the hood.
It appears I have oil pushing up through my breather cap on the passenger side valve cover. The oil has leaked down and onto the starter and is now starting to leak out the transmission inspection cover.
What is causing this oil to force its way out the breather?
Old 06-29-2008, 05:22 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
What type of engine, and vehicle information? Does it smoke out of the tail pipes? Do you have a PCV valve in the left valve cover, or just a breather also? Lot's of miles, or new rebuild? More information would be of more help..........
Old 06-29-2008, 05:29 PM
Frisco's Avatar
Glad To Be Here
Additional info would help.
However, if you have a vehicle that has a PCV valve; then I would check it and the line that connects it to the intake (manifold or carb base). If the line is plugged up or the PCV valve is stuck closed; high crankcase pressure will cause oil to be forced out. One of the places would be the breather cap in the valve cover. Others could include the front and/or rear main seals.
High RPM can also cause higher than normal crankcase pressure to force oil out of the breather. Been doing any hard acceleration runs lately?
Old 06-29-2008, 07:31 PM
Its a new rebuild with about 2000 miles on it. 355 sbc, no smoke out the tail pipe at all. Just installed some new AFR 195cc heads and it is running great. Never had the engine over 4000rpm and its only a Sunday driver. Has a new pcv valve and a new breather. Vehicle is a 1985 Buick Regal with 200R4 trans.
Anything else you need to know?
Old 06-29-2008, 07:39 PM
You may try a leak done test at TDC to see if there is a ring issue.
Is there a baffle in the valve cover under the breather??
If you have the PVC system correct there should be a hose going from the valve cover to the bottom of the air cleaner there is useally a knock out there.
Was the block plate honed using the same gasket and hardware that you put on the engine??
The Following User Says Thank You to CNC BLOCKS NE For This Useful Post:
MouseFink (04-21-2015)
Old 06-29-2008, 08:07 PM
PCV is hooked up correct but there is no baffle in the valve cover. The covers are Edelbrock Elite Valve covers. It is not consuming any oil at all just pushing it out the top.
The Following User Says Thank You to Regal Beagle For This Useful Post:
blue78 (04-22-2015)
Old 06-29-2008, 08:40 PM
My 2 cents worth
Wiki Edits: 3
In answer to your question. No and thank you.
We had a power outage for a short time, while I was trying to respond, and I see Carl @ CNC has already responded with the same sugestions I had.
You have a fresh "rebuild" that is a Sunday driver. You also responded there is no baffle in the valve cover. If you removed this baffle to be able to add oil quicker, this could be your problem. The oil spray from your rockers is going to keep the breather bathed in oil.
Old 06-29-2008, 09:32 PM
As far as I know there was no baffle in the valve cover.
very confused. Is there a fix?
Old 06-29-2008, 10:06 PM
My 2 cents worth
Wiki Edits: 3
If you do not have a baffle in that valve cover, the only way to fix it, is to buy a new set of "tall" valve covers. These will get the PCV or breather farther away from the rockers. Make sure they have baffles.
Since the oil is getting onto the exhaust(smoking)/starter/torque converter shield(lowest part of the engine/transmission), I would also check the rear of the intake, and valve cover gasket, for leaks. Especially if it is dripping on the ground.(you have not mentioned this but I suspect it)
Old 06-29-2008, 10:14 PM
I have actually gotten right up underneath the car and the breather is where I have sourced the leak to. It is leaking down from there onto the starter and into the converter cover and then onto the ground.
Why the heck did Edelbrock not put a damn baffle in thaose valve covers?
Old 06-29-2008, 10:46 PM
My 2 cents worth
Wiki Edits: 3
Only God knows why. Were they "Made in China"?(don't get me started going there)
I have installed valve covers in the past, that I had to drill, and install the grommet's for the PCV and Breather, then install the baffles.(supplied)
For it to be actually dripping on the ground, I'll bet the grommet is cracked, or loose.
Old 04-21-2015, 02:31 PM
Bandit2's Avatar
Olds 350 pcv
Hello guys. I have an Olds 350 engine in my bird and bought new chrome valve covers. I want to properly install the breather and pcv valve. Now I have pcv valve on driver side and breather on passanger one. However, I saw a couple of pictures with the pcv on passenger and breather on driver side. Which is correct or does the side matter at all? Thank you.
Old 04-21-2015, 02:41 PM
one side should be just the PVC valve and the other side should just be the breather and oil cap, basically you want to suck in air from one side of the engine to allow some kind of flow to the other side through the PVC valve and back into the engine/intake
The Following User Says Thank You to bigmac73 For This Useful Post:
Bandit2 (04-22-2015)
Old 04-22-2015, 01:29 PM
Bandit2's Avatar
thank you
Thanks bigmac73! Good to know that it makes no difference - feel much better now
oil suggestions and preferences timemachine Engine 2 05-07-2008 02:07 PM
gas prices and hotrodding ! engineman302 Hotrodders' Lounge 87 04-24-2006 08:27 AM
Where to find oil breather cap 1964 Oldsmobile 442 Engine 2 03-30-2006 11:53 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 12:47 PM
oil coming out valve breather? Brian Morency Engine 11 10-07-2004 03:50 PM
