Oil Restrictors - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2005, 11:03 AM
Dano1972's Avatar
New Member
Oil Restrictors
Hi everyone. This is my first post on this board outside of the intro forum. I did some searching and can't find a strait answer. My question is: I have a 468 inch BBC with a Comp XS290S solid flat tappet cam and Comp pro magnum roller rockers. The engine is still in assembly stages and I wanted to know if I should install oil restrictors. I have a melling HV/HP oil pump and remember hearing that a solid lifter cam and roller rockers need less oil to operate. The motor was running last year with a hydraulic cam and roller rockers showing 20-25 psi at 800 RPM idle when warmed up. I don't want to install oil restrictors unless I have to. Thanks to anyone that can help me out here.
Old 03-17-2005, 11:23 AM
The lifter will serve as the restrictor, so no, you don't have to install restrictors in the galleys.
To ease your mind though just call the lifter/cam manufacturer for verifcation, I'm sure they give you the same info.
Old 03-17-2005, 11:33 AM
King of my Man-cave.
I agree. The lifter will meter the oil that goes through it. Plus it doesn't make sense to supply any less oil to the valves, which are the least lubricated moving parts in the engine to start with. Another thing to think about are the valve springs. They need oil to be cooled.
tom
Old 03-17-2005, 12:41 PM
We make oil restrictors. No do not use on any hyd cam or solid flat cam.
Chris
Old 03-17-2005, 12:59 PM
Last journal entry: PICTURE TEST
restrictors
My vote goes to no restrictors also....
Keith
Old 03-17-2005, 01:08 PM
Silentlion_69's Avatar
Duck Tape & WD 40
Last journal entry: No more Vehicle
Why would someone want to restrict oil from the engine? I thought that the more oil pressure you had was a good thing
Old 03-17-2005, 01:44 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Restricting oil to the top end only. You don't need that much much oil when running solid roller stuff. To much of it causes windage as it falls back down onto the crank. That was the way ten years ago or more. Now with huge oil returns and better oil baffling and current trends to windage, you don't need the restrictors anymore.
Old 03-17-2005, 01:56 PM
Dano1972's Avatar
New Member
Thanks for the replies everyone. I'm glad they are not needed.
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 08:39 AM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 02:51 PM
A little humor Kevin45 Hotrodders' Lounge 8 10-21-2004 01:47 PM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
