Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil Restrictors or Not??
  #32 (permalink)
Old 03-22-2013, 07:55 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Ok, I did buy restrictors and put them in but then took them back out and plugged the holes. I'm running a 3 stage dry sump system and the Dart SHP block is designed for priority main oiling so flow to the bearings should'nt be a problem. I am running Lunati Solid Rollers (.300 taller), Comp Cams 3/8" Tapered Chrome Moly Pushrods w/T&D Shaft Rockers on AFR 227cc Aluminum Heads. Here are a few pictures of the motor, almost done. Thanks for all your input.
ID:	72506   Click image for larger version
ID:	72507   Click image for larger version
ID:	72508   Click image for larger version
