Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil Restrictors or Not??
  #36 (permalink)
Old 03-23-2013, 06:32 AM
MouseFink MouseFink is offline
Did you ever wonder why file-fit rings are .005" OS?
For example: File fit rings for a 4.030" bore are 4.035" .
Using file fit rings is a waste of time...and money, especially if you are paying some "expert" to fit them. You should install rings that selectively fit the bores as is.
Or, use Total Seal gap less rings, if you don't mind some ring flutter at high RPM..
