Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil Restrictors or Not??
  #41 (permalink)
Old 03-24-2013, 03:22 PM
CNC BLOCKS NE CNC BLOCKS NE is offline
Originally Posted by MouseFink View Post
Did you ever wonder why file-fit rings are .005" OS?
For example: File fit rings for a 4.030" bore are 4.035" .
Using file fit rings is a waste of time...and money, especially if you are paying some "expert" to fit them. You should install rings that selectively fit the bores as is.
Or, use Total Seal gap less rings, if you don't mind some ring flutter at high RPM..
Are you an idiot or what???????????????????? Where do you dream this stuff up???
You sure have made alot of my friends who build engines laugh.
If there were issues with egg shaped rings I think I would have seen it by now and my leak down numbers are under 2% Egg shaped rings HMMMMMMM
