Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil Restrictors with Solid roller cam and roller rockers
Old 01-06-2010, 10:23 AM
Guy Hiltz's Avatar
Guy Hiltz Guy Hiltz is offline
Heres what Crane Cams has to say about oil restrictors;
Newsletter Issues
Issue 222 January 2, 2007
Issue No. 222 January 2, 2007
Don’t Torch Your Valve Train With Oil Restrictors! - We do not recommend the use of lifter galley oil restrictors in either street or racing applications. Restrictors severely limit the flow of oil to the lifters, pushrods, valve springs, rocker arms and valve guides. This can greatly shorten the life of these components and cause them to fail! Your engine oil lubricates, as well as carries away the heat generated in these areas. Oil restrictors will raise operating temperature significantly and cause valve train components to prematurely fail. In roller lifter applications with high valve spring pressures, prolonged idling will also lead to less lubrication reaching critical areas, again leading to failure. The solution? Simple! You need only to occasionally “rev it up” and get oil flowing throughout the engine!
The Following User Says Thank You to Guy Hiltz For This Useful Post:
jtravis711 (01-12-2013)
