Some racers reroute upper end oil by terminating or reducing the typical Chevy flow from the lifter galleys, but they employ modified rocker covers that have an internal oil spray system that is used to cool the valve springs and secondarily lube the rockers. These systems are furnished with oil from externally added plumbing. This is a complicated and expensive solution to the problem considering the factory has a built in process. It does become a necessary addition for Grand National type engines where the hours long extended high speed running demands more precise cooling of the valve springs. But for the street and occasional races this is overkill. Bogie |
Heres what Crane Cams has to say about oil restrictors;
Newsletter Issues Issue 222 January 2, 2007 Issue No. 222 January 2, 2007 Don’t Torch Your Valve Train With Oil Restrictors! - We do not recommend the use of lifter galley oil restrictors in either street or racing applications. Restrictors severely limit the flow of oil to the lifters, pushrods, valve springs, rocker arms and valve guides. This can greatly shorten the life of these components and cause them to fail! Your engine oil lubricates, as well as carries away the heat generated in these areas. Oil restrictors will raise operating temperature significantly and cause valve train components to prematurely fail. In roller lifter applications with high valve spring pressures, prolonged idling will also lead to less lubrication reaching critical areas, again leading to failure. The solution? Simple! You need only to occasionally “rev it up” and get oil flowing throughout the engine! Guy |
| The Following User Says Thank You to Guy Hiltz For This Useful Post: | ||
jtravis711 (01-12-2013) | ||
Its been a while, but I finally got to checking if I have restrictors or not. I removed the 3 npt plugs in the rear of the block and they were just plugs. Is there any other places I need to check? Are there restrictors that go in the valley as well?
They are a smaller allen plug put into a tapped and threaded galley passage and have a small oil hole thru the center. |
I didn't think so but wasn't sure. I could see right through to the front of the block through the rear plugs. There is a valley screen kit installed I think thats where I got confused. I think I'm good to go. I just have to get thenew pilot bushing installed and I can bolt the tranny on and drop it in.
| solid roller make more power than my flat tappet cam? | jarrettandroski | Engine | 31 | 11-23-2009 11:55 AM |
| Right cam for a 383? | atomicrockerdude | Engine | 23 | 11-02-2009 12:13 AM |
| SBC adjusting roller rockers. | pittbull7934 | Engine | 27 | 10-05-2009 06:30 PM |
| Oil restrictors for roller rockers? | curtis73 | Engine | 11 | 10-26-2006 02:55 PM |
| solid roller cam...lifter broke! | chevyelc81 | Engine | 7 | 09-05-2003 01:41 AM |
