Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil Ring Tension question
Old 04-08-2011, 06:08 PM
eloc431962's Avatar
eloc431962 eloc431962 is offline
Evil Wicked Mean And Nasty
Wiki Edits: 37
IMHO it would depend on what the purpose of the engine was. If it's just a carburated engine the the standard should be what you need.JMO Now if it has juIce or boost on it then you would go the other direction with the low tension. IIRC the low tension will be a thicker ring where the standard is thinner. thin works fine on a street engine but not so good on a race engine. JMO "STREET ENGINE STANDARD TENSION" "RACE ENGINE LOW TENSION"
So if you go with the low tension it will probably use some oil and foul a plug every now and then.
Someone might say different but this is how i see it anyway.
Cole
