Oil sender - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2011, 04:47 PM
Footstomper
Last journal entry: 40 ford/cadillac coupe
Oil sender
I took the gauges with cluster, everything working. When I pulled the panel cluster out of the dash. I had been using successfully up to now. I was using a flathead oil sender. I decided to loosen the oil sender to make sure if it is pumping, it was working. But not the sender, it did not work. I have a 500 cadillac.
What sender should I use with 12V cluster (forty ford). I think I bought a 500 sender if I can find it.
Just anything that is reliable?
Thanks.
Footstomper
Old 02-24-2011, 02:22 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
You need to stay with the year and brand of the dash gauges because the sender and gauge are matched.
I assume that the gauge is electrical and not mechanical.
I assume the gauges have a voltage reducer (12v to 6v) installed or are from a 12 volt donor car.
vicrod
Old 02-24-2011, 03:01 PM
Footstomper
12V with 40 ford gauge and sender
I have been tidy the harness. I pulled the dash to get to the wires. Yesterday, it was working fine, all the gauges. I only turned the dash and it quit working. I have a tractor temperture gauge works, Alternator, I think the fuel may work, it is low. Now oil, I loosened the sender and turn it on and it has oil pressure. Why do those gauges just no more. I think I might just put the dash back in and see if it comes up after a while. I checked all the fuses.
oil pressure sender jjpodlas Engine 2 10-12-2007 04:38 PM
GM speedo sender longt Electrical 5 05-23-2005 01:41 PM
oil pressure sender DDGETHS Engine 4 01-24-2005 08:58 PM
Oil Pressure Sender Silver_Camaro Engine 7 08-12-2004 10:35 PM
Fuel Sender Help 84layinframe Engine 2 05-25-2004 06:52 AM
