Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Oil smells like gas 85 Impala
Old 07-27-2012, 02:28 PM
85impala 85impala is offline
Ok so I have a 86 olds cc-qjet I found in the garage, I'm going to do a quick rebuild, make sure everything is sealed up real nice then grab a banjo inlet and switch out the base plates because the throttle linkage is different.
Hopefully this will work but it's going to be a week or so before the banjo inlet and air horn gasket arrive in the mail
