Oil smells like gas 85 Impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2012, 12:09 PM
Hey guys, I have a 85 Impala with a 305 and cc-qjet. I recently changed my oil about a week ago because it smelled like gas, and now it smells like gas again just not as strong as before.
I have an innovate a/f gauge that's reading around 15 so I know its not too rich. I also replaced a leaking mechanical fuel pump with the airtex brand for 16$.
What would cause the gas to mix with my oil?
Thanks,
Clint
Old 07-26-2012, 12:14 PM
delawarebill's Avatar
fuel n oil don't mix well
well u really only have 2 places.. either the new pump is no good or your carb is leaking down and running into manif and into cyl and past the rings.. a pain, but maybe a compression test might say something..
Old 07-26-2012, 12:41 PM
Thanks for the reply
I actually did a compression test about 2 weeks ago and the whole driver side was the same @ 135psi and the passenger side was @135psi except #2 was 140.
I also can hear a faint drip right when I shut the car off, could the float bowl leak that fast after I turn the car off?
Old 07-26-2012, 12:45 PM
Q-jets are notorious for the well plugs leaking. Get the engine hot, remove the air cleaner, shut down the engine, hold the throttle full open and wait. After a little while you'll probably see a white vapor cloud coming from the carb. Leaking well plugs. Time for a rebuild.A lot of mechanics epoxy the existing well plugs but I never had any luck. They always leaked again. Here is where you can get o-ringed replacement plugs. Call them with your carb #. There is two sized plugs.
Carburetor Parts for Rochester Quadrajet, 4G, 2G & Carter AFB, AVS, Thermo-Quad Carburetors
The Following User Says Thank You to boothboy For This Useful Post:
85impala (07-26-2012)
Old 07-26-2012, 01:07 PM
Wow thanks for the info, I'll try that soon and post back here with my results.
Old 07-26-2012, 01:20 PM
DoubleVision's Avatar
More than likely it's the fuel pump. While yes Quadrajets do leak down the majority of it evaporates when it hits the hot intake so not much makes it into the oil. In my experience in almost every case it's the fuel pump.
When you replace the pump make sure you pack the pump cavity with moly or break in lube, this will assure the pump is lubed and will do so until oil can make it's way down to the pump. After you change pumps you'll have to change the oil and filter again as if you leave it then it won't be long before it'll cause excessive wear and it'll be rebuild time.
Old 07-26-2012, 01:29 PM
Cool, is there anyway to see if its the fuel pump?
Maybe unhook the inlet and wait for a drip?
Old 07-26-2012, 02:08 PM
Not really, when the fuel pump gets ruptured it just drains down and follows the curves into the oil pan. It cost about $15 for a new fuel pump so even if I'm wrong and I don't think I am your still not out much by replacing it.
The Following User Says Thank You to DoubleVision For This Useful Post:
Old 07-26-2012, 02:16 PM
Ok cool thanks for the help
Old 07-26-2012, 11:44 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The newer Q-jets almost never leak at the well plugs. If they ARE leaking, the engine will either take a lot of cranking before it starts or will start then immediately stall until it's cranked or run enough for the float bowl to refill.
Below is what epoxy looks like after a brief exposure to gasoline. Marine Tex epoxy is supposed to last better but I've never used it to say first hand, and there are several types- Ruggles has info on Marine Tex if you ever wanted to try it (click on image for article on rebuilding a Q-jet):
And here's those cheesy little pads the rebuild kits include, before and after being installed for a while. Utterly useless:
The method that has the best track record for staying fixed (no rubber o-rings or epoxy) is to tap the plug holes for a threaded plug as shown below:
There's a chance the fuel pump diaphragm is bad as DV said. Or that the fuel pressure is too high (you need ~4-5 psi). There's also a chance the needle and seat isn't shutting off the flow. Or that the float has become fuel logged and that is causing the float level to be too high. One thing that will sometimes help is to use a carb filter (the one that's inside the fuel inlet housing that the fuel line attaches to) with the spring loaded check valve on it, not the type w/o the check valve- either will fit.
In any event, if the carb is allowing fuel to get into the engine when it's shut off, I'd want to be real sure this wasn't also happening as you are driving- if it is, the excess fuel will wash the oil from the cylinder walls and that leads to rapid ring and bore wear. You might want to pull a couple plugs to check them for having black dry deposits- meaning a too-rich mixture.
The Following User Says Thank You to cobalt327 For This Useful Post:
85impala (07-27-2012)
Old 07-26-2012, 11:54 PM
I just took the SMI Quadrajet back off my truck's 4.3 V6 so I could fix the main wells. All I did was the same as I always do, remove the base plate and give each one a good smack with a hammer. Then I'll lay the carb on top of a bucket, fill the bowl with fuel then peek in to see if any fuel is dripping out. In every case I've did this thus far it's solved the problem. The SMI Quadrajet I have had the main wells epoxied but they still leaked so I used a wire brush to remove it then gave'em a smack with a hammer to seal them off.
Old 07-27-2012, 11:26 AM
Thanks, all that info helps greatly.
Im almost positive its not happening while its running because the air fuel ratio gauge is around 14>15 so almost all the fuel is being burned.
The car does crank for a little while before it wants to start, I hit the gas a little and it fires right up so I'm thinking its the float, those plugs or the pump.
I haven't had a chance to check anything out yet but hopefully I'll get a chance today
Old 07-27-2012, 11:30 AM
That's a few good ideas
Thanks I'll definitely try that
Old 07-27-2012, 02:28 PM
Ok so I have a 86 olds cc-qjet I found in the garage, I'm going to do a quick rebuild, make sure everything is sealed up real nice then grab a banjo inlet and switch out the base plates because the throttle linkage is different.
Hopefully this will work but it's going to be a week or so before the banjo inlet and air horn gasket arrive in the mail
Old 08-03-2012, 03:26 PM
I got everything in the mail and switched the carb.. when I pulled the carb the intake seemed dry and so did the fuel line and inlet. What was weird is the float bowl was dry and the needle was seated but I could still blow a tiny tiny bit of air through the inlet.(on the old carb)
Now I have to do an oil change and bend the fuel line so it can reach the banjo inlet
Thanks again everybody for all your help, I'll update soon once she's running
smells like gas after acceleration 1964 Oldsmobile 442 Engine 5 06-07-2009 06:30 PM
Smells like gas powerrodsmike Engine 3 08-05-2006 09:22 AM
exhaust smells like gas toddtheodd Engine 10 05-14-2004 02:58 PM
89 chevy 350 oil smells like the oil under the main caps. Jared Engine 2 10-24-2003 07:21 AM
smells like gas mshellw Engine 12 07-26-2003 03:38 PM
