Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil and spark?
Thread: oil and spark?
Old 02-25-2002, 05:02 AM
57Chevyman 57Chevyman is offline
I have never used an accel unit before. If you are only driving the car use your HEI. It is all ready set up for it right. Check to see if the gasket is in place or damaged. you may need a new gasket and a little Aviation Form-A-gasket.
Good Luck!
