oil on spark plugs of new engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 12:34 AM
BlenderHead's Avatar
my 350 chevy small block was recently rebuilt (less than 100 miles on it) and there is quite a bit of oil on the spark plugs, especially on the threads of the spark plugs. So oil is somehow getting into the combustion chamber, but I'm not sure if it's the valve seals or the piston rings. There is also some carbon build-up on the end of the plug. Not sure if the carbon and oil are related.
The repair manual said that oil on spark plugs can sometimes be found on new or newly rebuilt engines before full oil control has been established?? I'm not sure what that means. Could it be that I didn't break-in the engine properly?
Thanks to anyone who can help with this.
Old 10-25-2010, 03:02 AM
Originally Posted by F-BIRD'88
Either the intake manifold gasket is sucking in oil or the PCV valve is sucking in oil (caused by a lack of PCV breather baffling in the valve cover) or the valve covers are leaking oil down on the spark plugs.
Yes that oil can migrate thru the spark plug threads and get into the motor.
thanks for your reply. I do have the baffle in the valve cover under the pcv valve, the valve cover gaskets are not leaking, I guess i could check to see if the intake manifold gasket is leaking internally, but I'd really rather not take that off if I don't have to.
Just wondering... why don't you think it might be the valve seals or piston rings? is it because they are new and should not be leaking, cause that's what I think.
Old 10-25-2010, 04:16 AM
The faults I listed are the most common cause of oil consumption/smoking exhaust/oiled plugs on new engine installs.
Check the intake manifold for vacuum leaks. Check the PCV hose for oil.
New rings do not smoke. Unless they were installed upside down or are broke.
Or the motor suffered severe piston ring cylinder wall fuel wash and scuffing from carb flooding on inital start up.
Missing intake valve seals is a possibility.
Smell the oil on the dip stick. Does it smell like gas? Is the oil in the pan now overfull? fuel in oil.
Most of the pretty aftermarket valve covers PCV baffling design "sucks"
Once you have found and correct the oil issue, a few good WOT power runs will seat the piston rings.
ok, cool. i'll check that stuff.... thanks.
Engine Break-in Oil Psi HELP!!!!! eball Engine 29 02-21-2009 06:26 AM
Anyone have a guide on how to gap spark plugs on custom engine? timothy9972 Engine 13 08-20-2007 07:47 PM
Oil filter Super Magnets? Jag Daddy Engine 59 02-01-2006 07:36 PM
Spark Plugs Are Light Grey/whits And Their Is Oil On The Threads 70SPORT Engine 1 05-26-2004 12:25 PM
Spark Plugs Are Light Grey/whits And Their Is Oil On The Threads 70SPORT Engine 1 05-26-2004 06:56 AM
