oil spits out dip stick and breather
i have a 77 350 gmc in a 87 chevy truck and the oil spits out the breather and the dip stick when there in place and the pcv valve is in. when take out the pcv vavle or the breather it runs good no oil is spiting out , the engine sounds good and i did a compression test that was 165-160 on all tests no one around here can give me a reason head gasket?
Tha PVC sucks air out creating a major vacuum. So make sure you have an opening on the opposite valve cover. Most dude call that a breather. That will fix your problem. Good luck
