Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - oil stick leak
Thread: oil stick leak
Old 11-28-2001, 03:41 AM
tm454 tm454 is offline
Tazz
Post
I have found the high volume oil pump was all I have needed, might be part of the problem. What are you doing with this engine when its reving to 6000rpm? how long ago did you rebuild this engine? maybe the rings have not seated yet. if you used moly they thak longer than normal.
