oil temp gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2007, 04:43 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
oil temp gauge
Where do you plug in an oil temperature gauge on a SBC? A guy near me has a brand new one for sale for $5 so I figured might as well put it in..
Old 10-19-2007, 04:58 PM
boatbob2
oil pressure guage..........
HI,guage goes in back of the block,close to the distributer,you will need a brass fitting.
Old 10-19-2007, 05:19 PM
Wiki Edits: 2
so I should tee it in with my oil pressure gauge? I figured the oil up there wouldn't be as hot because its not really flowing.
Old 10-19-2007, 07:23 PM
Most of the kits I've seen for an oil temp gauge use a T in the line to the oil cooler, or in the line to a remote filter.
Bruce
Old 10-19-2007, 07:25 PM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Do'nt think so, The options are this, first as far as I can find there are no electrical oil temp gage/sender (motor) available, second you are probably aware that the temp probe on a mechanical gage is on the large side. So here are the choices, if you have a remote oil filter you could tap into that line with a T and using some pipe hardware engineer it, the only other place would be to remove the oil pan plug and install the probe there.......... however this will work best with an oil pan that has the drain plug on the side, example: street/strip oil pan. The install of this gage takes a little thought and wrenching but defiantly not impossible.
Old 10-20-2007, 11:25 AM
Wiki Edits: 2
Yeah I guess the best would be to put a bung in the side of the pan, seems like too much trouble though.
Old 10-21-2007, 09:26 AM
Vortech 4.3's Avatar
jack of all trades
WRONG . autometer has an electrical oil temp gauge. i have it on my engine. the sender is in the pan.
Old 10-21-2007, 02:09 PM
cmscott
put it in the pan
i have a big block chevy that i put an oil temperature guage on. i tried to tee it off the oil pressure guage and it didnt work. i dont think the oil pressure in the line to the pressure guage circulates while the engine is running (?). either way, i put a bung in the oil pan on the passenger side, mainly because the tubing (mechanical auto meter) would clear everything better. now the guage works perfect!
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
Oil gauge question? Jag Daddy Electrical 2 03-19-2011 06:37 PM
Adding an oil temp gauge to SBC - how to? Porchev Engine 2 03-28-2006 11:51 PM
Eratic temp gauge 51f1vee8 Electrical 1 09-16-2005 06:55 PM
Underhood oil gauge? Jag Daddy Engine 19 12-15-2003 08:33 AM
