Yes, you can use it. Trans temp Gauges come with several Max degree ranges, up to 250*-400*.
You could also use a Tee fitting in the Cooler return line for Temp reading. Example >> http://static.summitracing.com/globa.../bmm-80212.pdf |
I just tapped my aluminum pan and used the smallest brass adapter with thread locker.
The BIG picture. |
oil temp gauge instead of trans temp gauge
Thank SSedan 64 for the redirection to the Summit sight.
EOD Guy: It's a Turbo 400 that came with a factory installed deep [sheetmetal] pan. I think it may have been out of a 3/4 or 1 ton truck, but not sure. I picked up a NIB, B&M deep, finned aluminum pan on Craigs for $50 and am planning on using it. I live in the Phoenix-metro area. July /August temps are regularly in the 110-115 degree range... which probably equates to 125/130 or more coming off the tarmac. I'm thinking about a seperate trans cooler with a small fan for those "extra-warm" days. |
malc: Nice clean install job. What I was wondering was, where is your exhaust? I see the tube ahead of the oil pan... is that a crossover pipe? My vision isn't as good as it used to be, but you seem to have the cleanest tuck job on your exhaust I've ever seen. Tell me where you hid it !
TH400 didn't have a extra bung for a temp sender..... If you're going to use the B&M..... now would be a good time to install a fitting..... If you have a welding shop, they could weld a bung to the side very easy, if not I have used a brass fitting that was threaded into the pan and a brass coupler, cut off like a nut, securing it from the other side, with JB weld sealing everything permanently
If you don't want to drill the pan you could also use a fitting that goes inline in one of the cooler lines. Several companies (e.g., B&M) sell them to go with their gauges. I assume you want to measure the temps in the line going out to the cooler.
Bruce |
before paint and pre aluminum trans pan.
| Transmission temp gauge? | kyle86 | Transmission - Rearend | 5 | 07-10-2010 11:56 PM |
| Autometer trans temp gauge, can I take apart? | bubbahotep | Electrical | 5 | 04-07-2009 07:40 AM |
| oil temp gauge | fiscus | Engine | 7 | 10-21-2007 01:09 PM |
| temp gauge | steve t | Engine | 5 | 04-14-2005 07:48 PM |
| Temp gauge | grandprix601 | Electrical | 2 | 03-17-2004 08:45 AM |
